LEXAN GLASS
Old Jun 27, 2001 | 07:47 PM
Suaveat69's Avatar
LEXAN GLASS
Does anybody know if lexan glass for the rear hatch will open or if it is fix shut?
Old Jun 27, 2001 | 09:32 PM
Camaro_hunter_d's Avatar
I would imagine that if you moulded the lexan to the shape of the glass, the entire peice then you could loose a few pounds and still have it work normally. You will need vacuum bagging equipment, available from www.aircraftspruce.com . Go to the page and check it out. But if you can get the vacuum bagging stuff and the release film, you can also get the lexan from them too then make it swap it in. It will cost more then 200 in equipment alone, unless you can find someone to do it for you.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Marc Brown
Fabrication
17
Sep 25, 2015 03:43 PM
F-body-fan
Sep 24, 2015 08:29 AM
SG91camaro
Sep 5, 2015 10:27 PM
