Umi vs jegsters subframe connectors
Old Mar 9, 2013 | 07:06 PM
MY87T/A's Avatar
Car: 85 IROC "SYNASTR-Z"
Engine: 355 SBC
Transmission: 700-r4
Axle/Gears: 3:73 disc brake
Ok, so I'm turning my ttop Iroc into a targa and I'm going to be getting sfcs. Well all the searching only gave answers to not get competition engineering. So now I'm stuck between Bmr or umi at summit. Or to get Jegs ones and weld them up. I'm looking at which ones tie the car together the best. And which ones require no modding to the car chassis.
Old Mar 9, 2013 | 07:30 PM
MY87T/A's Avatar
Engine: 355 SBC
Re: Umi vs jegsters subframe connectors
I'm also looking for which ones make it more sturdier. I've read alston ones tie it together really well.
Old Mar 9, 2013 | 07:40 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
yes alston are really well becuase it ties the front and back good. I traded my spohns ones for a set of alston.
Old Mar 9, 2013 | 07:42 PM
MY87T/A's Avatar
Engine: 355 SBC
I was planning on Alstons till I seen the cost with shipping. I'll probably just get some otters right now like umi or something and later on get the Alstons.
Old Mar 9, 2013 | 11:01 PM
BigKeg's Avatar
Car: 87 Black Irocz28
Transmission: 700r4 shift kit
Axle/Gears: 3:73 richmend axles and eaton gears
When I had my iroc in the body shop, getting shaved...I asked them if I got some SFC if they would put them in ...so I bought the UMI ..gerat people too deal with...and I'm very happy with the SFC....body shop said they went in just fine...
I too want to-do a taga top...My pics are on my profie ..
Old Mar 10, 2013 | 03:58 AM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
the umi or bmr subframe connectors would probably be to weak for a targa top since they connector to the lower control arm brackets instead of the accuall subframe. alston would probably be your best options for subframe connectors another option you have if you are willing to do work is find a convertible in a junkyard and remove all the convertible reinforcements and use them.
Old Mar 10, 2013 | 04:12 AM
BigKeg's Avatar
What convertible reinforcement ???? As fare as I know, they took T-top cars...and sent them off to have the top cut off...I could be wrong, I never had a vert...But if you have pic's or diagrams showing this ...Please post them...
Old Mar 10, 2013 | 02:57 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Either one's will work, iv personally installed jesters, good design and strong.
If your going to targa top your car then...
Old Mar 10, 2013 | 11:15 PM
MY87T/A's Avatar
Engine: 355 SBC
If only I could use that lol.
LT1Formula
Oct 8, 2015 08:34 PM
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
