why are the rims rubbing?
Old Jul 14, 2001 | 08:39 PM
92 z28's Avatar
I need some quick help, do you know if the stock 92 rims are the same sizes all around? Because I have just rotated my tires, and the tires in the front are rubbing against the tire rod. any help would be greatly appreciated.
Old Jul 14, 2001 | 08:54 PM
tiogarider's Avatar
I don't know about camaros but the Pontiacs have an offset on have back wheels. So they won't interchange. But that is the Pontiacs
Old Jul 14, 2001 | 10:24 PM
orange rocket's Avatar
The 16" rims are specific to front or rear they are labeled so look closely and you will see.
Old Jul 15, 2001 | 11:06 AM
91z4me's Avatar
Yeah like was said earlier the back rims and front ones aren't supposed to be changed.
Old Jul 15, 2001 | 04:05 PM
92 z28's Avatar
is there anyway to get the rears on the front?
Old Jul 15, 2001 | 06:00 PM
Jza's Avatar
Jza
to rotate, you have to take the tires off the rims and rotate them.
Old Jul 15, 2001 | 06:27 PM
Demon Z28's Avatar
Car: 2001 Camaro SS
Engine: Almighty LS1
I never saw the point of rotating the tires on F-Bodies...
But that just might be because I've got wider tires on the rear than I do on the front
Old Jul 15, 2001 | 10:46 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
92z28,
I think this depends if you have 4 wheel discs all around or drums on the rear. I had a 91 rs and it stated on the rims "front" and "rear" on them.
Right now I have a 92 z28 with 4 wheel discs but have not checked to see if the rims are all the same. I would assume that they are.
Hope this helps!!!
Manny
92 z28, 350, 47k miles, pw, pl, power mirrors, power drivers seat, rear defroster, 4 wheel discs, perfomance limited slip axle, leather and Heritage Package
Old Jul 16, 2001 | 09:36 AM
Disc rears are the same rims as a drum setup. It is a back spacing issue. Think about the 15" you crank your wheel all the way, you get a rub. Go to a wider tire ie. on 16" rim and more rubbing. The rear also have to tuck in the wheel well properly and with out rubbing on inner skirt. The only way to get away with both... Different back spacing on both front and rear rims!
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
MrPackstin
Oct 25, 2017 08:09 PM
kitt23
Exterior Parts for Sale
Nov 28, 2015 06:26 PM
dbrochard
Oct 10, 2015 01:03 PM
