T top complete removal
Old Apr 17, 2013 | 04:52 AM
khunter's Avatar
Car: 82 Z/28
Engine: 5.0
Axle/Gears: 323
Well the title says it all. I've got an 86 iroc z and I've hot a guy wanting the body to make a dirt at out of and I'm taking the t tips off before he buys it and I want the center bar as well. How hard is that to get off?
Old Apr 17, 2013 | 06:35 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Re: T top complete removal
You need to pry the t-top weatherstripping up to reach 4 more screws (2 up front, 2 on the rear end of the bar). Loosen them and the rest of the visible screws (3 on each side I think) and you'll be able to wiggle it up and off.
The necessary force depends on how much sealant has been put under it.
Old Apr 17, 2013 | 12:22 PM
khunter's Avatar
Car: 82 Z/28
Engine: 5.0
Axle/Gears: 323
Well ok they are completely original and don't leak so it shouldn't be to hard. They just haven't been ou in 20 years
Old Apr 19, 2013 | 01:33 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
If the t-top bar is not rusted, it shouldn't be too difficult. Just follow the steps above. If it is rusted, plan on it being somewhat of a pain and coming off in multiple pieces.
Old Apr 19, 2013 | 02:04 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Put your screwdriver in place and give it a whack,this will allow you to remove the screws without rounding the screw heads.
Old Apr 19, 2013 | 02:10 PM
BigKeg's Avatar
Car: 87 Black Irocz28
Transmission: 700r4 shift kit
Axle/Gears: 3:73 richmend axles and eaton gears
I took mine ...it was a pain in the @ss...mine was rusted, and it didn't come out nice... I had all new metal put in..I have pics on my profile. ..but if you are selling the car, why do you want the T-bar ???
I can understand the tops...
Old Apr 19, 2013 | 02:56 PM
khunter's Avatar
Car: 82 Z/28
Engine: 5.0
Axle/Gears: 323
Well bigkeg my plan was to remove incase some one wanted to do a t top conversion. I want to save everything on this car before I scrap it. I'm honestly debating just cutting it off at the fenders so it would be a complete swap over. Just got new keys cut for the tops yesterday so that they are removable now
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
3rdgenparts
Aug 8, 2015 07:09 PM
