Slam hatch to button release hatch, no prob
Old Jul 25, 2001 | 12:40 PM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
To all of those that said this could not be done, here is what i did. I wanted to switch my regular old slam hatch to one where i could press the hatch release button and it would pop, but i didn't want the problems usually associated with a pulldown motor. I scavenged a pulldown motor from an 86 trans am, and after a while of tinkering, i found myself with a release solenoid. Looking on the hatch release bracket from the 82 trans am, I noticed that there were very similar mount points to those that i found on the pulldown bracket. so, to make a long story short, after i broke off a tab, the solenoid bolted right up to the bracket. Im not sure if the hatch release was ever offered on the 82, but these parts are completely compatible. I removed the cable that operated the lock cylinder on the pulldown motor and ran one hot wire up front to a button in the dash. I couldnt have imagined this being any easier. I've been kicking myself for not noticing this earlier. If anyone wants to know more about doing this, just ask
Jeff
Old Jul 25, 2001 | 03:04 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Here's what I can add. The solenoid release and pull-down assy are two separate items. In fact the convertibles have the pull-down assy, but lack the solenoid. I added the solenoid as well as the associated relay, wiring & switch to mine. Since mine is a convertible I didn't want the trunk release button visible. I got a trunk release button from a wrecked 80's Caprice and mounted it in the center storage compartment. Much happier now. 8^)
90 RS Convertible
Owner: Top-Down Solutions
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old May 1, 2017 | 09:00 PM
roberthodges84's Avatar
Re: Slam hatch to button release hatch, no prob
Do you have a hatch trim panel on the car? If so what did you use? My stock one can't cover the solenoid. Any idea if the electric cover will work?
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
jrdturbo
Mar 31, 2016 02:58 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
formula00ra
Sep 28, 2015 11:50 AM
