Rear Fenders?
Old Jul 24, 2001 | 10:14 AM
Quick-Z's Avatar
Rear Fenders?
Would any body have any idea on the best way to roll the inner rear fenders up to get rid of the sharp edge?
Old Jul 25, 2001 | 07:22 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Well it depends on if your trying to roll the entire edge up, or just get rid of the "sharp edge" as you said.
As far as getting rid of the sharp edge, the best way is to cut slits about 1 1/2" apart and maybe (actually at least) 3/8" deep. Then use a pair of vise grips to bend the metal up and over about 120 deg. Then clamp it down over to 180 deg. That is called a hem.
If you wanted to totally get rid of the inner edge, do the same thing, but make your slits go all the way to the quarter panel. Then bend them all the way up into a 90 deg angle. I'm not sure you could do that without messing up the paint.
Hope this helps.
AJ
[This message has been edited by AJ_92RS (edited July 25, 2001).]
Old Jul 25, 2001 | 08:20 PM
Quick-Z's Avatar
Yea, I don't want to take the chance with the paint, so I'd rather try your first idea..Thanks
Old Jul 26, 2001 | 12:37 PM
89RustangRemover's Avatar
http://www.gr8ride.com/cgi-bin/pm/ar...aro&oid=112424
you'll need Acrobat Reader to download the complete article...
http://www.adobe.com/products/acrobat/readstep.html
in case you need the Reader...
hope this helps ya out some...later.
"WARNING: Objects in mirror are about to disappear VERY quickly!"
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
kah992
Aug 19, 2015 02:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
kyleb24
Aug 15, 2015 08:24 AM
