Help with headlight switch
Old Jul 31, 2001 | 09:25 PM
slowmaro92305's Avatar
ok, i am replacing my gauges with white faced gauges. right now the 92 rs is sitting in the driveway all apart. i cant figure out how to remove the headlight switch to get the cluster out. i took the dash pad off but still cant seem to get at it. i also removed the lower pads where ur knees are when u are driving. i cant get out the cluster with the headlight switch blocking it. please help with quick answers. thanks!
Old Jul 31, 2001 | 09:32 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If your switch has the pull **** like the older camaros (and most old GMs), there's a button on the switch unit itself that you have to press while pulling the **** out. You'll have to unplug the switch to turn the lights off. there is a nut that then hold the switch to the plastic) I assume that's what you were asking about ? (I've never paid attn to the newr dashes in the junkyards)
The mind is like a parachute, it only works when its open
Old Jul 31, 2001 | 09:46 PM
Hulk0202's Avatar
Theres a trim piece that goes over the gauge cluster and the switch. You have to take it off first.
Old Jul 31, 2001 | 10:52 PM
i removed the trim plate but i cant get the cluster out because the pull headlight switch is in the way. there is no notch or button to push on to take off ****...i cant figure out how to remove it...
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
Randomtask2
Sep 10, 2015 08:37 AM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
