hood wont stay up???
ive bought three sets of pistons now to hold up the hood and im still using a stick. what am I doing wrong? all oem new sets, all fit exactly on as described, but none of them will keep the hood up. any suggestions??
Car: 1992 Camaro (Z28 Clone)
Engine: LB9|TPI
Re: hood wont stay up???
I dont know if the base model hoods weighed less than the IROC hood or the Z28 hood but its a possibility when you get them make sure you tell them you have an IROC not just a 1989 camaro.. just my
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
http://www.autozone.com/autozone/par..._0_3184%2C6098
You need to make sure your buying for a STEEL HOOD.These struts hold my TA hood up with no problem and these hoods have to be one of the heaviest made.
Car: 1986 IROC-Z
Axle/Gears: 4:10
Agreed. Some earlier models had a fiberglass hood. If not check your hood hinges. I had to replace mine as well.
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
