protective door molding
Old Aug 8, 2001 | 07:22 PM
87firebird's Avatar
I have rust starting on my door and I was thinking of sanding it down and Painting it. The only thing is the protective door molding things. They run down the middle of the door and are about 1" wide. I saw that they were glued on. Do they make glue that glues them back on, so I can peel it off, re-paint, then glue it back on. IF they do make it were could I get some.(NAPA...)
Old Aug 8, 2001 | 10:09 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The (urethane/rubber or whatever it's made from) moulding should be held on by double sided trim tape. The tape is available just about anywhere that carries car stuff, made by 3M (usually), even Wally-World (Wal-Mart)
The mind is like a parachute, it only works when its open
[This message has been edited by deadbird (edited August 08, 2001).]
1Aauto
Sponsored Vendors
Feb 8, 2017 03:09 PM
1992Z28!
Nov 19, 2015 07:33 AM
tglennon11
Sep 23, 2015 05:30 PM
Linson
Sep 21, 2015 01:08 PM
