trunk panels
Old Aug 9, 2001 | 09:43 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
trunk panels
how can i freshen my rear trunk panels that conceal the spare tire and such without buying new ones???? i was thinking about getting them carpeted........any ideas........how much would this cost to do?
Old Aug 9, 2001 | 09:53 PM
nicmike85's Avatar
We have an interior spray at our shop. This can be done only on plastic panels. It works great. It won't cover gouges but it makes them look new. Check a body shop. We use Sherwin Williams.
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You could spray dye them as well. Clean with acetone or laquer thinner thouroughly, spray with adhesion promoter (bulldog is key, available at paint suppliers in aerosol cans) then dye, mar-hyde & duplicolor make great aerosol dyes. I prefer duplicolor because of the fan spray tip myself but to each their own. They do make dyes that you can mix for paint guns (that work a little bettr) but for trying to cover what you are doing, it's not really worth it. Using a scotch brite pad to scuff the plastic before using adhesion promoter helps as well.
The mind is like a parachute, it only works when its open
Old Aug 10, 2001 | 03:17 PM
deacon17's Avatar
You can buy a carpet to cover them with, it's sometimes called flex form carpeting. www.mrmikes.com sells it. This stuff is cheap and all you have to do is lay it on the panels and cut to fit. It's good for using on the top of the panels but not on the bottom half. But you don't really see that part anyway. . . otherwise you can paint or dye which will polish it up a little but that doesn't cover scratches well. If you use carpet, you need some that stretches or you'll never get it to fit around the curves of the plastic very cleanly.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
FormulaEngland
Sep 30, 2015 01:50 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
