Glasstek 4"
Old May 19, 2013 | 12:14 AM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Glasstek 4"
Who's got one? Can I see some various pictures as well as an inside view so I can see visibility levels? Trying to determine if I want to swap my cowl hood out and get one of these instead for the future BBC swap. Car is getting painted soon so I definitely need to make up my mind.
Old May 19, 2013 | 04:30 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Glasstek 4"
Check out this link and it shows the bolt on 82 to 92 4"
http://www.glasstek.com/
Its not a Camaro hood but it does show how deep it is towards the middle.
Old May 19, 2013 | 10:27 PM
Engine: TBI,5.0
Re: Glasstek 4"
OK, found one. 4in. Glasstek cowl
Old May 20, 2013 | 12:50 AM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Re: Glasstek 4"
Ah, very nice! That's not that bad visibility-wise from the looks of it. What do you think? Tolerable?
Old May 20, 2013 | 03:40 AM
Engine: TBI,5.0
Re: Glasstek 4"
Hay, if its necessary than I could get used to it. Mines a DD street car so the 2" fits me perfectly but even though its a true cowl 2" is not much to work with. CA is pretty strict about stupid stuff and Ive heard rumors that it could be considered a visual obstruction.If its on the street allot than you might want to look into it before paint .Last , that's one large cowl opening , no worries about getting enough air but I think I saw in the other photo that you can keep the hood cowl weather striping in a attempt to keep water from free falling into the bay. Just a thought.
Old May 20, 2013 | 04:36 PM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Re: Glasstek 4"
I've got a 2.5" KeyParts hood (ours appear to be the same exact hood if you recall correctly). Only major difference is that it's a steel hood and obviously extra clearance. I didn't go with fiberglass the first time around because I wasn't sure of who to buy one from, but Glasstek seems to make decent quality stuff from the reviews I've seen across here, YellowBullet, Chevelle, and LS1tech. That and I've had fiberglass before and it's a massive difference in weight, particularly if you're working on the car by yourself.
We'll see I guess. It's another $600, and I'm currently finishing paying for my 6 point rollbar setup.. so I've got time to decide.
Old May 20, 2013 | 04:50 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Glasstek 4"
I have the 4" bolt on from GlassTek on my Firebird slightly different but I'm 6'4 and I can't see the passenger side headlight when it's flipped up. Just for point of reference.
My glasstek has a rain channel built in it. It does a fair job of collecting the rain and keeping it off the distributor.
It also has all attachments for stock hood hardware (spring and latch).
I bought mine 2nd hand off eBay because it was damaged and previous guy didn't want to fix it. There is a shot of my hand next the cowl.
Be warned the corners have around 1" of extra material that hung down and covered up almost 1/2 of my turn signals. I trimmed it back and smoothed out the two piece design on the front lip.
loud91rs
Oct 5, 2015 10:05 PM
JUNKYTRANSAM
Exterior Parts for Sale
Aug 6, 2009 09:29 PM
LFN AT U
Mid-West Region
Apr 19, 2007 10:36 PM
LFN AT U
Apr 12, 2007 03:02 PM
