C&C T Top adjustment
I've got a not so small leak from the t-tops. From the drivers side, you can actually look across the roof and see the passenger t-top sitting higher than the drivers side in the middle of the car. I know how to make adjustments to the outer attachments but is it possible to adjust the fit where the two tabs on the t-top go into the center bar in the middle of the roof? There doesn't appear to be any adjustment to the tabs on the tops or the slot pieces on the roof but I might be missing something that someone else has seen.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: C&C T Top adjustment
Remove the rubber trim.The nuts are behind the tabs, in the frame.Im guessing you have the vent type tops.
Yeah, I've got the vent type tops. So the rubber trim around the opening hides nuts that will let me lower the slots on the on the roof... I'll take a look when the car comes out of the paint shop..
gixxer92
Sep 1, 2015 04:32 PM
