Frame Damage
Old Aug 7, 2001 | 12:33 PM
RSRagtop's Avatar
Frame Damage
I have a 91' Rs 'vert, when I bought the car some frontend damage was hidden from me. Both front frame stubs were crushed, then hammered back out, covered with bondo, and then painted to hide it. Well as you have probably guessed, the frame is shedding its bondo. I have located several good frame stubs and radiator supports in mid 80's cars, I planning to cut them off and weld them to my car to repair the damage. The cars are Berlinettas, will their parts work with my Rs nose and gfx? My car also needs a new hood, can the Z28 power blisters be mounted on any 82' to 92' flat hood? Is the bracing the same?
Old Aug 7, 2001 | 12:47 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
The blisters won't fit on a flat hood. The hood needs to be from a Z28 or Iroc.
90 RS Convertible
Owner: Top-Down Solutions
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Aug 9, 2001 | 02:06 PM
red350Z's Avatar
isnt that a lovely surprise . my 91 Z had the driver side frame and rad. core sapport changed. it took me awhile to figure out why there was blue paint in the engine compartment of a red car
91 Z28 slp headers adj reg accell cap rotor coil comp cam roller
random tech cats flowmaster catback
new motor in
Old Aug 13, 2001 | 10:32 AM
ATOMonkey's Avatar
I guess I got lucky. I'm doing the same thing right now. Bought an '89 crashed, but he hit an SUV so it never hit the bumper. The engine stopped the car. I used all the pieces off of an '87. The only problem I ran into is that the molding from the doors doesn't line up with the molding on the fenders (D'OH). Other than that everything lined up real well.
Old Aug 13, 2001 | 01:45 PM
Mo's Avatar
Mo
Around here somewhere is a post about some blisters on ebay that are made to fit on flat hoods, they are a little bigger, but I couldn't tell from the pic.
90 IROC 5.7l (L98)
ram air, K&N's, air foil, full exhaust
LIKE A ROC
http://members.nbci.com/IrocZgarage/home.htm
no green
Jan 9, 2016 09:22 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
TheCardinal
Interior Parts Wanted
Oct 9, 2015 09:43 PM
88CamZ
Oct 8, 2015 10:29 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
