Power Window Adjustment
Old May 21, 2013 | 07:09 PM
Black_TA's Avatar
Car: 1983 Trans Am
Axle/Gears: Stock
OK, this is day 3, I replaced my drivers side power window motor,what a job.
The window works but how the heck do you line up the window to stay in the
triangle piece. Do I push the felts to hold the window back. I read everything
possible,still cannot align the window. Any trick or ideas. Everthing is new ,
felts gaskets door panel. 1983 Trans Am.
Old May 21, 2013 | 08:00 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Power Window Adjustment
Try adjusting the triangular piece instead.Unless the window is not sealing properly against the weather strip.Its a multi step process, adjusting one thing will mis-align the glass elsewhere.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
zayne0
Aug 24, 2015 07:22 PM
stalkier
Aug 21, 2015 01:54 AM
