my tilt steering is shaky...i need some help!
Old Aug 13, 2001 | 06:20 PM
ballen's Avatar
can anyone tell me how to expose the tilt steering joint? mine is really loose (gives about an inch in every direction) but i cant get that plastic collar off without breaking it to pieces, or do i have to pull the wheel off and remove the blinker and stuff? all i know now is i may need a torx socket and some threadlocker, which i have. I just need to know how to get to the bolts or whatever to tighten the f**ker back up! i would really appreciate any advice, thanks!
Old Aug 13, 2001 | 07:53 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Well I've run into the same problem. But I always take it to the dealer, for that one reason, I'm afraid to break the column. I can fix and get to almost everything but that, it only cost 20 bucks at the dealer.
Old Aug 14, 2001 | 01:54 PM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
Remove your kickpanel, lie on your back and look up under the column. You'll see ?two? big bolts attached there. Loosen them off a bit, have someone move your wheel to the position you want, and tighten the sh*t out of the bolts. I'm pretty sure that's your problem.
Old Aug 14, 2001 | 07:25 PM
mckenzie's Avatar
hello, yes you must take the steering wheel off to access the 4 torx bolts. its a deeper in the column than you think. i suggest you take it to the dealership if you have never been there before...too much stuff to mess up. best of luck, tom
86 iroc 305tpi auto. mild cam
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
