how do you adjust firebird headlights ???
Old Aug 16, 2001 | 10:47 AM
smurfmobile's Avatar
so how do you adjust firebird headlights when they are CLOSED ?
I'm trying to realign all my body panels and stuff , and the lights are a little bit down (front of them are lower than the top of the fender).
how do I adjust this ???
thanks
Old Aug 17, 2001 | 01:39 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
There are four bolts that you can loosen to adjust them, you move the entire assembly to give you a hint.
Unfortunately it is alot easier without the front Facia. What you will have to do is get a 10mm socket and loosen them. You might have to go as far as installing some shims under the bracket to get things to work right. Turn on your headlights and adjust, and turn off your headlights to see if it aligns right. Repeat till it looks the way you want it to. You can also wind them by hand.
John
Old Aug 17, 2001 | 11:55 PM
Dark_Boba's Avatar
turn the dial on the motor.
1992 Trans Am
May 10, 2023 07:19 PM
1992CamaroGirl
Dec 25, 2017 08:45 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
DiabolicalRS
Aug 26, 2015 07:35 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
