how do I remove my door panel??
Old Aug 15, 2001 | 02:04 PM
Camarokid01's Avatar
I know how to unscrew the armrest and I know how to pop of the window roller but how do I do the rest?? 86' sport coupe
Thanks in advance
Old Aug 15, 2001 | 03:13 PM
Blue_Meanie86SC's Avatar
k, take off the plastic trim piece, there's a hidden screw under one of the blank rectangles. take the rectangle off by pushing down and towards you. as for the panel itself, all you have to do is pull. start at a bottom corner to make it easier. Once you have all the fasteners free, put the window crank on without the clip and roll the window down. Then for the plastic piece on top, push in and lift up, there are 3 clips on it. It should come off with the door panel unless someone ripped the panel.
Old Aug 15, 2001 | 05:26 PM
camaro chick's Avatar
Do this all very carefully. I made myself a tool to get the push in fasteners off around the whole door panel so that I wouldn't rip them off from the cardboard backing. It's a little fork like tool with two prongs- it'll make your life easier, especially if you have to take the door panels off regularly (like I end up doing about 4 times a year).
Old Aug 15, 2001 | 10:43 PM
thanks everyone
Old Aug 18, 2001 | 08:14 PM
Faught's Avatar
I know body types between Cams and Birds are similiar. does the bird door trim come off the same way?
85 standard bird
Old Aug 18, 2001 | 11:23 PM
yeah, they're identical for birds and camaros
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
