1991 front lower valance question
Car: 2017 Jeep Cherokee
Transmission: 6 Speed, 5 Speed T-5
Okay guys, finishing up my resto on my 1991 rs. It has the ground effects with the scoops. I had to replace the front lower valance with the scoops from too many years parking to close to curbs. Long story short, ordered one, painted it. I can quite get the gaps to close up where it attaches to the front of the fenders. There are two alignment tabs that slot into the fenders, but right above that there are some mean gaps that aren't supposed to be there. Is there a way to fix this? Is there some clip that attaches to the tabs? Any help would be appreciated.
Thanks!
Thanks!
Car: 91 Camaro Z28
Axle/Gears: 3.42 Posi Disc
Re: 1991 front lower valance question
91- 92 had 4 clips. 2 each side that inserted into the tabs and held the ground effect close to the fender. Two of mine have came out and I am trying to find them as well. No luck finding them. Trying to fab up a simple but effective work around. Good Luck!
Car: 91 Camaro Z28
Just found this from another post! The clips!!
Hey guys just passing on some info that I know I and others on the board had been searching for some time. I finally found a supplier for the clips that hold the 91-92 nose ground effects spoiler to the fenders on the camaro. I got them thru www.clipsandfasteners.com. They are PN A17382 (GM Bumper Valance Panel Retainer). Cost a wopping $5.13 for a box of 25 of them. This is actually a good site for some off the wall fasteners. I have attached a couple pics so you can see what I'm talking about. Have a good one
Click image for larger version Name: 2013-02-15_14-12-32_634.jpg Views: 44 Size: 502.8 KB ID: 254124 Click image for larger version Name: 2013-02-15_14-12-05_797.jpg Views: 18 Size: 649.4 KB ID: 254125
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Great find. Thanks. This will help a ton.
1992 Trans Am
May 10, 2023 07:19 PM
