digital dash
Old Aug 28, 2001 | 01:48 AM
85 Berl's Avatar
digital dash
I have a 85 Berlinetta with the digital guages. None of them worked, so I ripped them out with the control "pods". Does anybody know if regular controls (turn signals, wipers, ect.) will plug in to the wiring harnesses, or do I need to rewire?
Old Aug 28, 2001 | 12:35 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
a regular camaro (or Z) electrical system swap into a Berlinetta can be done - BUT
You would need to remove/replace 70-80% of the interior to make it work. I was able to install an 86 Z28 dash into an 85 Berlinetta,..... but it took an entire IROC parts car and a lot of patience. I was lucky in that the Z had an LG4 engine (same as the Berlinetta) and the "bulk-head" connector matched up pretty close. Only the wiper systems had to be rewired at that spot.
A brief listing of what you would need
1) AC/Heater system from the a camaro (Both side of the firewall!)
2) floor console from Z
3) Steering column from Z
4) ENTIRE dash housing from the Z
5) Mechanical speedo Sending unit from the Z
There's more - but I'm sure you get the point. If you find that you need Berlinetta stuff, let me know...
John in RI
Berlinetta@Prodigy.net
Old Aug 28, 2001 | 10:28 PM
85 Berl's Avatar
Sounds like I may come out better getting a new car. It only cost me $500.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
