Access port to take fuel pump out in hatch?
Old Sep 1, 2001 | 10:21 AM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
has anyone cut out a section of there floor pan in the hatch area for easy access to the fuel pump?Since I have a parts car here that I'm taking the tpi out of I was thinking about cutting a section of the floor pan out of it that can be pop-riveted back down on a slightly smaller cutout in my RS for easy fuelpump access.How large a piece would I have to cut out to actually access it?
92RS
Old Sep 1, 2001 | 11:27 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
The butcher mechanic where I used to work did that all the time. He would use weatherstrip adhesive to seal the hole up. I think you would have to cut a few holes to get at the fuel pump on a thirdgen. Is the trackbar bracket in the way?
92Z28
89GTA
Old Sep 1, 2001 | 03:06 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
I'm not sure if the "trackbar bracket" is in the way or not.I'll find out when i cut up the parts car.Thanks for the response.
Old Sep 1, 2001 | 05:59 PM
MNformula350's Avatar
Do it the right way or take it to someone who will!!!
I used to work at a GM dealer and i could do the fuel pumps in third and fourth gen f-body's in about 1-1/2...you'll spend that much time ripping up hte interior and butchering the body>
84 FIREBIRD-(undergoing rebuild)2.8 V6,5spd,T-Top
90 Formula Modded 350 TPI T-Top
WANTED:82-84 Firebird 2.5 4cyl,4spd-Just Cause
Previous 3rd gen's
83 Trans-Am 305 CFI auto T-TOP
84 Firebird 305 H.O. auto HARDTOP
87 Firebird 2.8 V-6 auto HARDTOP
Old Sep 1, 2001 | 06:17 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Unfortunatly, you'd be wasting your time & having to cut and extremely large hole in your floor, comprimising some structural integrity of the floor. The lines from the sender are solid steel that go from the sender to the coupler on the frame rail on the drivers side. The snder is also deep and you have to twist it in a couple funky ways to get the float out, with the steel lines attached, a small hole just isn't going to get it.
2nd, the tank isn't but an inch from the floor so you would have to be pretty dammed careful cutting.
Last time I put a pump in it took the better part of 2 hrs, alot less time than dicking around trying to cut a hole then having to fab up a way to put the piece back in place (in which case you'd have to take the tank out anyways defeating the purpose of the hatch)
Just something to think about
The mind is like a parachute, it only works when its open
Old Sep 1, 2001 | 08:19 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
ok,ok,....you guys have changd my mind.I guess i'll have to do it the right way.lol
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
