Rattle noise isolated...sorta
Old Jun 26, 2013 | 05:45 AM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
On my 1989 Firebird Formula, I have had this rattling sound for a while now. I found it comes from the right side of the car. I can feel the vibration where the center console meet the carpet on the passenger side right near the seat belt. what lines or cable run near the center console under the car that might cause that rattling?
Old Jun 26, 2013 | 07:30 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Rattle noise isolated...sorta
The ebrake cable is there , but more likely its something from the exhaust like the mount for the cat or something. If its more subtle than that, could be coins in the console. Some cars I pulled had pounds of nickels and dimes in the console.
Old Jun 26, 2013 | 08:00 AM
ken3983's Avatar
it is definitely on the outside under the car. I have heard it for a while but head slowly progressed since then. I will run the car on ramps and see if I can find anything in that area.
Old Jun 27, 2013 | 07:34 AM
stealtht/a's Avatar
If its outside, it can only be an exhaust part or cable or hard line that has come loose. Should be easy to see what's doing it.
Old Jun 27, 2013 | 09:01 AM
ken3983's Avatar
come to think about it it may be the transmission mount. it has never been replaced on this car so maybe it is about time. that would explain the rattle in the location where is it coming from
Old Jun 28, 2013 | 09:00 AM
stealtht/a's Avatar
I would think a loose mount would cause more of a banging or knocking. Rattling implies a more constant noise at certain harmonic, mounts generally just thump or bang when force is applied. If you stand by the description of "rattle", its prob your exhaust.
db057
Jan 10, 2020 08:55 PM
jrdturbo
Mar 31, 2016 02:58 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
GouldyGTR
Sep 7, 2015 09:05 PM
