NEED HELP - REMOVING HATCH!!
Old Jun 28, 2013 | 09:14 PM
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
Axle/Gears: 3.23 - Posi -10 Bolt
Just like the title says, hope this was the correct place to start this thread.
I have a 91 RS Camaro that I am parting out, (posted in classifieds), and I can't get the hatch open. I don't have a key, and I have removed the battery and all other electrical components from under the hood.
How the heck can I get this off? I need to sell the hatch, spoiler, tail lights, etc (all available for sale). Plus, I need it off to get some of the interior parts out..
Old Jun 28, 2013 | 09:15 PM
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
Re: NEED HELP - REMOVING HATCH!!
Come to think of it.. I don't even see anywhere to use a key.
I was going to just use a drill and drill out the lock mechanism.
I am stumped...
Old Jun 28, 2013 | 11:00 PM
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
Bump - 28 views - No suggestions?
Old Jun 29, 2013 | 12:01 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
There should be a key lock on the centre panel between the tail-lights. It operates a cable that leads to the hatch release. Don't know if it's removable from the outside without breaking things, or even if the cable is operable without the key if you did.
Or, crawl inside from the rear seats and try to remove the plastic to access the release, I've read of guys doing that - search it.
Or - grab a 12v source and apply to the release wire from inside the cabin.
Old Jun 29, 2013 | 12:03 AM
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
Or - grab a 12v source and apply to the release wire from inside the cabin.[/quote]
This sounds like the easiest way, thanks!
Old Jun 29, 2013 | 12:50 AM
Josh Graybeal's Avatar
Car: 1992 Camaro RS Heritage Edition
Engine: 305/5.0L
can't pull the license plate down?
Old Jun 29, 2013 | 06:34 PM
my82roc's Avatar
Car: 89 Iroc Convertible
In the boneyards I usually pop out the rear cargo light then reach inside and tug on the cable.This will pop the lock open
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
scottmoyer
Sep 7, 2015 07:06 PM
90formulaVortec
Sep 7, 2015 06:54 PM
