anyone putting on gfx should read this...
Old Sep 3, 2001 | 12:21 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
well, i am pissed. i started putting the ground effects on my car tonight. its a 89 bird that i am making a T/A replica. i got fenders off a 84 T/A. you know what? the damn fenders wont work. apparently the extractor thingy is to big, the gfx actually goes over it. ohhhh i am not happy. i thought it would work, and posted it on here and got replies saying it would work, but thats the way it goes i guess. i am gonna look at it again in the morning, maybei maybe i am wrong. well, just wanted to let everyone know. lil jay
Wide Open Till You See God...Then Brake
Old Sep 3, 2001 | 01:01 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Checked the archive using search, apparently I never saw you ask. The gfx on the older, 82-84, t/a's had smaller (height) gfx all the way around so the side baffle was larger. The p/n's don't match either so they were (the baffles) 2 differnt style/size parts.
If you had gotten a pair of standard bird fenders, it wouldn't have been a problem (there was no extractor). If you can score a pair of standards, you could make a replica GTA (GTA's had no side extractors). But,, since junkyard selection sucks, that might be a PITA to do. The guys at Universal are pretty cool tho & have descent prices.
Or, you could just tack weld some sheet metal in & dough over it. I'd even let you borrow my welder
The mind is like a parachute, it only works when its open
Old Sep 3, 2001 | 05:19 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Those extractors are only $14 or so each without the screens, but the screens fit both styles of extractors.
I have one from my 86 that is the kind you need, it is the passenger side one.
I put on some Camaro 91-92 rocker panels and I needed the extractors with the long vents.
If you need it, let me know.
WS6 Trans Am.
View My Ride @ thirdgen.org
Old Sep 3, 2001 | 11:19 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
If I was around when you posted, I would have told you that 82-84 T/A fenders are different than 85-90 Fenders, 91 & 92 they changed them again, no extractors.
sorry, I was late.
John
Old Sep 3, 2001 | 01:07 PM
MNformula350's Avatar
The fenders are not different just the size of the air extractors.
Just get some from a 85-90 T/A and you will have no problem-(the extractors just pop out of the fenders they are only held in by cllips).
84 FIREBIRD-(undergoing rebuild)2.8 V6,5spd,T-Top
90 Formula Modded 350 TPI T-Top
WANTED:82-84 Firebird 2.5 4cyl,4spd-Just Cause
Previous 3rd gen's
83 Trans-Am 305 CFI auto T-TOP
84 Firebird 305 H.O. auto HARDTOP
87 Firebird 2.8 V-6 auto HARDTOP
Old Sep 3, 2001 | 08:11 PM
Nightcruzer's Avatar
Car: Trans Am
LilJayv10,
I was one of the guys who answered your question regarding the bolting of 86 TA gfx on 83 TA fenders dated August 14, 2001. You simply asked if it could be done (and you didn't state your original year or model of firebird) and I said yes, IF you drilled new mounting holes. All 82-92 TA fenders are identical with the exception of the GTA and 91-92 TAs, which shares the identical fender with the 82-92 formula or base model firebird. The ONLY differences are the gfx mounting hole locations (hence the need to redrill the holes for the particular year gfx) and the visual design of the extractor (the extractors are the same size dimensionaly). For the complete TA replica conversion, you are going to need an 85-90 nose with the molded in gfx or your fender gfx are not going to line up with anything on the front bumper.
So, I hope this cleared some things up, and yes any 82-90 gfx WILL bolt to ANY 82-92 fender PROVIDED you redrill the mounting holes for the gfx.
From the classic industries catalog:
Original GM fenders
part numbers G8999 RH 82-84 TA (4 gfx holes)
part numbers G9901 RH 85-90 TA (3 gfx holes)
G9003 RH 85-92 GTA, formula and standard, AND 91-92 TA (no extractor)
I am looking at the pictures of the actual fenders and they are identical, even the extractor location. The only differences are the amount and location of the gfx mounting holes hence the different part numbers.
[This message has been edited by Nightcruzer (edited September 03, 2001).]
Jake_92RS
Jan 28, 2020 10:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
Thaney9
Aug 7, 2015 08:25 PM
