how do i remove the manual window handles?????
Old Sep 5, 2001 | 09:24 AM
87_Camaro's Avatar
i just bought some very nice "beefy looking" window handles for my camaro,"wheni say windoe handle i mean the ones that you turn ot open the window" i needed to know how do i remove hte old ones so i can pop these baby's on? do i just pull them?? is there soemthign special i must do? please help then ill take a pic and show everyone
Old Sep 5, 2001 | 12:26 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Sometimes you can fool around with a screwdriver to get them, but for $7 you can get the right tool. It just slides behind the handle and releases the clip. Essentially it's held on with a C-clip type fastener. You need to slide the tool in parallel to the handle (and on the same side as the handle) and I usually shield the back side so the clip doesn't go flying off to never-never land. Then you just put the clip onto the handle and push it back on to reinstall.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 7, 2001 | 12:20 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
He's right about the clip...new GM cars are still mafe the same way. If you're just replacing the handles, that's the easy part...but get the tool, a right angle pick works too...
Old Sep 7, 2001 | 05:07 PM
reborn's Avatar
Ive allways just used a thin pair of pliers when I needed the handles off. Works just fine.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Polo Z03
Sep 10, 2015 06:43 PM
stalkier
Aug 21, 2015 01:54 AM
3rdgenparts
Aug 8, 2015 07:09 PM
