Scratch repair question
Old Sep 18, 2001 | 08:34 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I posted this a couple days ago in the appearance board and got nothing so I thought maybe it's better suited for this board. Anyways, here it is:
Okay I was walkin to my car and noticed quite a big, ugly new scratch on my passenger side rear fender. Its not dented, so I think I can fix it myself. Do I just have to sand it down, primer it, and paint it? Any recommendations on what grit to use/what paint/primer? Also, should I clearcoat it when its done? Thanks.
1992 Camaro RS
5.0L TBI
Custom white-faced gauges
K&N Airfilter and ready to take on the world!
My 1992 RS
USA
Old Sep 19, 2001 | 09:04 AM
Nightcruzer's Avatar
Car: Trans Am
depends on how deep it is. Drag your fingernail across the scratch. If the scratch is deep enough to catch your fingernail, then yes its, sanding, priming, painting. If not, try rubbing compound first!
If you need to sand, hand sand the scratch with 220 grit on a sanding block or wood paint stick, do not use your fingers (it will create grooves). As for primer and paint you have to find out what type of paint is already on the car and use the same type i.e. acrylic enamel, urethane, laquer.
Do a search for the words "painting" on this forum for more detailed info.
[This message has been edited by Nightcruzer (edited September 19, 2001).]
Old Sep 19, 2001 | 09:31 PM
Car: 1989 IROC-Z
Engine: 383 stroker
How do I find out what kind of paint is on my car?
1992 Camaro RS
5.0L TBI
My 1992 RS
USA
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
deracer
Apr 11, 2016 12:04 AM
redmaroz
Aug 16, 2015 11:40 PM
