Super 77, How ?????
Old Aug 19, 2001 | 04:50 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Super 77, How ?????
Ok, on the headliner fix, you guys recommended super 77 from 3m, and so I bought new headliner material, and i brushed off the old headliner foam junk. It stuck for a few days, but then, the thing juss doesn't stick, it only does this in the heat (90 or higher, or whatever makes the roof too hot to touch) Now, would contact glue work, I saw some non-flammable stuff at home depot, but then it said "Non-flammable until 140 f", now i think it gets that hot b/twn the roof and the headliner.
Stock 2.8 MPFI auto w/ Flowmaster 80 Series, More to come......
New Pioneer Head Unit
Targa E-910 7-Band Equalizer w/ crossover
2x 10" Pioneer subs powered by 300 Watt Jensen amp
2- 6x9" Pioneer (rear)
More to come..... (hey, i dont got a job yet)
Old Aug 20, 2001 | 12:05 AM
89V6FBIRD's Avatar
btt, oh and if you guys want to know what the question is, IS THERE ANYTHING THAT WORKS BETTER THAN SUPER 77 ????
Old Aug 20, 2001 | 10:36 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
YES, try the 3M 90, it is better up to a higher heat. AND there is a place here in the Greater Flint area where I can get High temp headliner spray adhesive, it works as good as if not better than the 90. its in a Gold can. I get it at a upholstery fabric shop.
Old Aug 20, 2001 | 11:57 AM
Blue_Meanie86SC's Avatar
question 89V6, How did you apply the super 77? Did you just spray it on then bond the two surfaces together, or did you spray each surface, wait about a half hour then bond them together. Super 77 (and most other upholstery adhesives) works like a contact cement, so you have to let it fully tack up in order for it to make a good bond.
Old Aug 20, 2001 | 01:28 PM
Saywhut's Avatar
I also got some stuff in a gold can from an upholstry supplier that works great, if you follow the directions about tack time.
It's called Performance Aerosol Products
"Performance High Temp Trim Adhesive", R.J. Ackaway & Associates, good stuff........
Old Aug 20, 2001 | 04:30 PM
89V6FBIRD's Avatar
I sprayed both pieces (headliner and fiberglass) and then waited about 20 min before sticking them together, HI-strength 90??? hmmmm I don't know. It gets really really hott here in so-cal, last time I looked at the thermometer in my dad's expedition it said 138 f inside the car! Just imagine how much hotter it would be in a thirdgen.
Old Aug 21, 2001 | 12:25 AM
<font face="Verdana, Arial" size="2">Originally posted by Saywhut:
</font>
Yeah!! that's the stuff I used on my door panels. works great! I'm sure you can get it through most any auto upholstery shop.
Old Aug 21, 2001 | 12:32 AM
89V6FBIRD's Avatar
hey that sounds good, time to take a trip to the little upholstery shop I know near my grandma's house!
Old Sep 20, 2001 | 08:17 PM
89V6FBIRD's Avatar
OK I brought this post back from the dead. But I finally got around to fixing that headliner. I used 3M's General Trim Adhesive and today it got really hot in there, NO PROBLEMS AT ALL!!
Old Sep 20, 2001 | 10:06 PM
The_Maniac's Avatar
Adhesive for carpet - NONE (it's been said, the seats, bolts and what nots hold in molded carpet). I've got picks of new carpet being slid in after a floor pan replacement on my web site.
Headliner Adhesive - Not over the counter sprays. My step brother and I did 2 f-bods with 3M and a couple of weeks later, the work was worthless (adhesive gave out). My father has recently re-upholstered 2 headliners beautifully with light coats of standard CARPET glue.... Light enough not to seep through the liner, yet it's tacty enough to hold as good as factory!
Many of us here are ameteurs here with different experiences and good input, this was just my 2 cents.
'84 5.0 liter v8 Z28 Camaro
'93 3.3 liter v6 Grand Am SE
http://www.lightstream.net/~the_maniac/
no green
Jan 9, 2016 09:22 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Zell1luk
Sep 29, 2015 10:36 AM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
