how would i do this....?
what's up, i have an 85 ta, with an 85 mph speedo...i want to swap it for the 145. mainly because they look so much better than the one i have..but it's nice to know how fast you're really going too! anyway, my speedo is mechanical, and it's a 5 speed. so how could i convert to the electronic 145 cluster? and would all the other gauges work with out a problem? thanks a lot
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I have an idea that I KNOW would work but it is more work than you are probably wuilling to do. Buy an 86-92 Firebird (wrecked) with everything on it that you want, like the 145 speedo, and convert everything over, including the dash wiring. It sounds like a big difficult PITA, and it is, BUT, it is doable, and you would know more about your car than most people.
Be a GREAT time to convert to TPI if you do not already have it.
John
Somehow I think that is not an answer you wanted to hear.
On the other hand you might be able to isolate the circut that the speedo works on, FOR SURE you would need the transmission sender, the wires going to the speedo and the speedo & the electronic stuff inside. I think it might work if you got that stuff. Because I know my speedo seems to work fine without the computer. When I bought my car I had a friend tow me with his suburbon and my batt was dead dead dead, and the speedo still worked. Still would be a PITA.
John
G O D BLESS AMERICA
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
John
John
G O D BLESS AMERICA
5.1 TPI Automatic
83 Camaro (Parts)
83 T/A (parts)
Guest
Posts: n/a
Can you use a mechanical 145 speedo? There's one for sale on the classified board. It's from an IROC. Are they different than T/A speedo's? https://www.thirdgen.org/internal/cl...cfm?adid=12594
If you can't use an IROC speedo, they do sell an electronic speed sensor adapter. It screws into the trans, then the cable screws into it. I guess you'd have to run wires from there to the new tach.
thanks guys, yea the iroc and ta have different gauge clusters entirely...if it's gonna be to much of a pain, i was thinking about doing what 'karpsta' has done with his cluster. it looks great! does anyone know his aol screename or email so i could ask him how he did it? thanks a lot
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Have you checked under your car on the transmission to see if it's cable driven or has a vss (speed sensor)? If it has the vss, any newer 140 speedo will work.
The mind is like a parachute, it only works when its open
- my Formula Homepage
- Collision P/Ns & Diagrams (Nearly complete now!)
luvofjah
Sep 26, 2015 08:28 PM
Street Lethal
Sep 14, 2003 01:54 PM
