Cant find a place for foglights for my 3rd gen bird
Old Oct 2, 2001 | 11:49 PM
86BIRD-MY FIRST CAR's Avatar
i have a 86'firebird with those rubber or vinal inserts below the headlights. i really want to put foglights on but no where to put them!. any suggetions or a pic of a third gen bird with one?
Old Oct 3, 2001 | 12:31 AM
87 Firebird's Avatar
I've been toying with the idea of putting the lights right into those black areas. I'd use a sort of oval-ish light, and cut it in. Hart to say if it'll work well, but maybe I'll try it on a junker first....
Old Oct 3, 2001 | 06:48 AM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Hey man, if you have the money, try and pick p a nose from a T/A. You can find decent ones around for fairly cheap (at least around here) Then you will have your fog light cut-outs already.
Take care
Mike
Check out My Car Pics http://albums.photo.epson.com/j/Albu...667&a=13599419
Gran Turismo Americano "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs
Old Oct 3, 2001 | 08:36 AM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
dont forget the ground effects to go with it...you will need them if you get that front fascia...just get a 91-92 formula nose....thats the way to go....
<font face="Verdana, Arial" size="2">I have experience......unfortunatly its a result of bad judgement......</font>
click below to check out the new Formula Source....
www.theformulasource.com
or click below to check out my Formula350.......
www.formula350.com
or click below to email me
webmaster@theformulasource.com
Old Oct 3, 2001 | 09:45 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Right under the front bumper you'll find 2 honeycomb plastic thingies, each held on with a single bolt. I mounted my fogs right to that on my 86 Firebird. It's a great place to mount them to. Just slide under the front of the car and you can't miss them.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 3, 2001 | 10:35 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I was thinking about taking a hole saw, probably about 2" in diamter, getting some round driving lights from some place like JC Whitney, or Summit, and making t holes in those black bumpers like discussed before. If you paint everything black in the hole you would not see anything but the lights if you do it right.
Get yourself a T/A driving light switch from a junk yard a relay to run the lights, and it would probably look & work great. (almost stock if you relly do a clean job.
John
G O D BLESS AMERICA
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
eightsixseven
Dec 16, 2024 01:50 PM
firebirdchick28
Mid-West Region
Aug 16, 2015 02:52 PM
Catcher55
Aug 15, 2015 07:08 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
reiderz iroc
Aug 13, 2015 04:57 PM
