How do i remove the dashboard to replace the gauge front plastic
Old Oct 7, 2001 | 11:58 AM
Marc van den Broek's Avatar
Hi,in my firebird '86 is in the gauge from the speedometer in the front plastic a huge brake.I want to replace the plastic or a part of it.but HOW DO I REMOVE THE DASH or can it be done simplier (Sorry for the bad spelling i'm from holland (EU))
Greetz Marc
Want to know everything aabout pontiac firebird from 1980 to 1989
Old Oct 7, 2001 | 05:23 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
To remove the plastic piece you need to take off the black cover that is in front of it. It has about eight hex screw holding it in (can't remember what size). After you get that off the plastic piece comes off with about six small bolts. These also hold an a metal piece that goes around the gauges. Be extra careful with the needles too.
I'm not sure where you can buy one but my guess would be a junkyard or Classic Industries.
Hope this helps,
Matt
1984 Camaro Z28 - Black w/ Grey int.
Best 1/4 - 13.6 (5-speed) & 14.0 (Auto & 2.73!) Est. 300rwhp & 345 lbs.ft. tourqe
-GM Goodwrench 350 with Edelbrock 600 Carb, Edelbrock Preformer RPM intake, AC Delco plugs, ACCEL wires, 14" Accel filter, Homemade Cold Air Indctn., Edelbrock Chrom valve covers, breather, and Air cleaner.
-TH350 with Hurst shifter & B&M Street shift kit.
- Eagle Alloys 15" Alum. Rims surrounded by P235/60R15 BF Goodrich Radial T/A's
Comming Soon:
3.73's, MAC Cat-Back, hollowed cat. & Paint: Navy Blue Metallic w/ Silver strips
Old Oct 8, 2001 | 11:00 AM
Thanks i'll give it a try.....
Old Oct 8, 2001 | 12:43 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Actually since you have an 86 you should need a 5.5mm & a 7mm nutdrivers.
Take off the top dash pad, To do so remove the 4 long screws in the defronster vent. Second remove the screws from underneeth the dash pad. Remove dash pad, and be careful when pulling it back, because this is a common time to break off the stubs that hold on the speaker grills.
Remove the right passenger trim piece 9under the dash pocket. Should be 3 (7mm) screws
Remove the 2 (7mm) from under the trim piece on the driver side where the Running light switch goes for Trans Am's
Remove the screws around the dark gray trim piece
Remove the dash panel (NOT the GOLD screws)
You may have to lower your tilt steering to its lowest level to get some of this out. AND remove the Tilt steering lever. Simply uscrew it.
Once you have the Instruments out then you can work on it easily.
IF you have all Indicator lights, you might have a Speedometer cable. If your car has the gage package you should not have a speedo cable.
Hope this helps
John
G O D BLESS AMERICA
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
Old Oct 8, 2001 | 01:36 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
What you dont have a cheap haynes book?
Well they do have some pics of where all the screws are that might help but you never know.
89 Formula Firebird
Red with T-tops
5.0 305 FI
Soon to be a 400sb.
Old Oct 8, 2001 | 09:11 PM
FiReBReTHa's Avatar
okfoz is a stud,.....
got it down,
yea, just remember to put all screws in a little baggy, lol, i see you wronte that you want to learn as much as you can about firebird 85-89....
Welcome to thirdgen.org...
all you need....
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
kyleb24
Aug 15, 2015 08:24 AM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
