Anyone MAKE their own door panels?
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I'm not talking recovering their existing panels,but making new panels from scratch. Has anyone done this and what were the results? If you have pics please post them. I'm looking to make some for my Firebird and plan on something close to stock but slightly custom.
Mongoose-NCTGA-1990 Pontiac Formula/305 TBI-700R4 with Edelbrock Performer TBI intake,TES headers,and STB,K&N,MSD-6AL,Holley laser shot coil,Accel Extreme 9000 wires,Jet Stage 2 chip,TCI shift kit with corvette servo,Richmond 3.73 gear with Auburn 3 series posi,high flow cat,SLP 3" cat back,Eibach sportline springs,Energy Suspension poly throughout,Lakewood LCA and adjustable panhard bar package,SSM subframe connectors,IROC wonder bar,Tokico 5 way adjustable struts and shocks,Autometer electric fuel pressure gauge,Alpine,JL Audio,MB Quart,92 GTA taillights,92 GTA aero wing and hatch,Steve Spohn LCA relocater kit and torque arm,MacEwen White face gauges,84 T/A cold air induction air cleaner,Grant Formula GT wheel.
Prime on www.NEThirdgen.org did. They were a bit simple but turned out rather nice for a first try. He was gonna try some better ones afterward.
I made some raised flame one that turned out pretty good. I had to cut new pannels out of masonite since mine were warped (also upholstery shops usually sell door panel board). Also make sure you have the fabric running the same way on both doors. I forgot this step and since I used perforated velvet one door looks black and one looks charcoal. Also, make sure you let the glue fully tack up before you bond the two surfaces. I had some spots of adhesive that were still wet when I bonded them and as a result I have bubbles when the interior temperature increases. If you have any other questions feel free to email me. I have pictures of them (although not good ones) that I can scan if you really want them.
1986 Camaro Sport Coupe
Stock 305 cid. LG4 engine
3" catback dual exit exhaust
Metallic Indigo Blue Paint
Gloss Black Interior
L69 dual snorkle intake
Car: 91 Firebird Vert
Engine: LO3
<font face="Verdana, Arial" size="2">Originally posted by Third:
Prime on www.NEThirdgen.org did. They were a bit simple but turned out rather nice for a first try. He was gonna try some better ones afterward.</font>
They were an attempt just to see how hard it would be. They were made totally from scratch. The morning after I made it I found these online.
They are made from abs plastic and include thier own monting method. They can be dyed or covered. They are $149.00 a pair and are made to be cut down to fit.
If interested here is there website, www.roddoors.com. They have about 40 diffrent styles.
[This message has been edited by Prime (edited October 04, 2001).]
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I'll be doing mine when I actually get to my interior. I've got a spare door panel that I'm going to use as a template to trace onto some ABS, then I'm going to more or less use the same, straight-across pattern on the front, except I'll use leather and carpet. A little dyanamat on the back and I'll be good to go.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
Car: 90 Formula
That's more like what I'm after. I'm planning to more or less copy the OEM style and design but replace the grey metrix cloth insert with either black vinyl or leather. The carpet section down at the cupholder will be a challenge if I decide to use it.
Anyone else had any luck doing this?
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
