What would all of sudden put the rear hatch/trunk out of allignment
Old Aug 25, 2013 | 08:31 PM
rwerk91's Avatar
Car: 91 Camaro
Engine: LS1, LSXRT &102mm TB, Cam,225 Heads
Axle/Gears: 9" 4.10 w/31 spline axles
Never get into the trunk really I know for a fact it would shut very smooth before.Only thing ive done lately was about 6 weeks ago swapped rear ends for a 9" the coilovers are a little off and was on stands for maybe 2-3 weeks but would that make the hatch off center a bit. Before trunk caught the auto latch nice and smooth now it has a little resistance before it catches like the bar on the hatch sort of grinds before latches and auto shuts (best terms I could think of to describe) Im not one of those guys who slams their hatch shut either always set it softly until the auto latch catches. Oh also I know one lift had blown out but it still worked fine. Any way to realign or set it. Never messed with body stuff. Always makes me nervous Ill never get it straight again. Thanks
Old Aug 26, 2013 | 08:22 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: What would all of sudden put the rear hatch/trunk out of allignment
Most likely when the support is bad, it bent the hinge. You can bend them back, but they are aluminum I think so they crack easily.
Old Aug 26, 2013 | 07:38 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
the hatch mechanism has nylon slides.they crack and break.http://www.top-downsolutions.com/new...atch-pull-down
Old Aug 26, 2013 | 08:00 PM
rwerk91's Avatar
Car: 91 Camaro
Thanks for the input guys. Went ahead and replaced both struts. Ends up one was good and the other completely dead. They exert a ton of force( hatch is really heavy) and I guess the good one was pushing enough for it to be outta whack. Shuts like new now.
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
zeitghaist
Aug 18, 2015 07:33 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
