Door Bushings
Old Oct 10, 2001 | 11:12 PM
83z4whldsk's Avatar
Door Bushings
Does anyone know where the large upper door bushings can be purchased? The lower ones are available but I can't find a source for the uppers without having to buy an entire hinge (expensive). I'm restoring the car and have the doors off so it was easy to grind off the pin rivited end to get the old pins and bushings out. I'll just spot weld or drill & tap the ends to keep them in place after. The door bushing kits in the restoration catalogues I've seen are only for the lower hinges.
Old Oct 11, 2001 | 08:07 PM
Belker's Avatar
I'd like to know the same thing. Have you checked to see if a dealership can order them? Or will a pin from another make/model car work?
Old Oct 11, 2001 | 08:42 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I have custom made third gen F-body upper door hinge pin, and bushing sets.
One set will do 1 upper door hinge (2pins&2 bushings). For $62.40 +shipping ($2.50 or so).
Thanx,ANDYZ28
Old Oct 11, 2001 | 11:25 PM
83z4whldsk's Avatar
Thx, but still too expensive. I may look into getting some made if cheaper. Do your bushings match the stock ones? If so how much just for them?
Old Oct 12, 2001 | 05:53 AM
ANDYZ28's Avatar
Car: 1982 Z-28
No my bushing do not match the stock ones. Mine are much better. They are made to aerospace quality.
If you get the bushings made? How will you get the pins? That was the problem I encountered.
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
camaro1185
Oct 26, 2015 06:51 AM
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
