Rolling on paint?
Car: 1992 Formula/2008 Mazda6
Engine: 305 5.0L TBI/2.3L tuned
Transmission: 700R4/5-speed auto
Rolling on paint?
Curious if anyone else has tried this.
I'm currently rolling on Rustoleum enamel paint using a foam roller and oil-based paint brush. It's turning out alright for the most part; Only on the second coat. Found out a foam brush doesn't work very well when I was putting on the first coat. Anyone else with experience doing this?
Car: 1991 GTA
Engine: LB9
Re: Rolling on paint?
In my opinion, if you have the skill(or at least the desire and determination) to get the body straight enough to make a roller paint job "look good", then you should do the body work, and while doing that save your pennies, sell your blood or semen, whatever. Take the proceeds, and get the cheapest MAACO single stage paint job thrown over your work. This will look much better than what you are going to get going the Rustoleum route.
But this is strictly opinion, and I will give credit to anyone that undertakes the Rustoleum challenge. At least you are trying to make your car better.
As for the paint, it's protective enamel by Rustoleum, using 1 part mineral spirits to 4 parts paint. It's oil based. The first coat will look crappy...this is to be expected. Make sure that you're using a foam roller, and a brush made specifically for oil-based paints for the small and delicate portions that your roller can't get to (I'm looking at you ground effects).
I cannot stress enough that you should not fill the roller up completely with paint when you start rolling. You need to roll off a lot of the excess paint, as you'll get incredible runs otherwise (I found this out the hard way).
The paint will take longer to dry than conventional auto paint that's sprayed on; Give it at least a day between coats, if not longer. It will flatten out and become smooth as it dries. The second coat will go on much more smoothly than the first, and will really start to shine. I'm currently going to apply the third coat this morning, so I'll let you know how that goes.
One of the key points in this is that it's cheap to do compared to normal paint jobs, but keep in mind it's all about how much effort you put into it. Another plus is that you don't need to tape off as much, as there isn't overspray to worry about. Keep all corners near where you're painting covered.
One last thing...don't do this at night. Or anywhere that bugs are a problem. They like this paint, a lot. They don't look good on said paint.
Yeah, that's a dent in the front fender. Not sure how that got there...still learning the story of this car as I tear things apart/replace things on it. Previous owners used it as a burnout car at a local speedway :X
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You could buy a gallon of enamel for $40, and a harbor freight HVLP gun for $12 on sale.
Nobody is against you painting the car yourself, we're just wondering why you would do it like you paint a bedroom.
-- Joe
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
[quote=Firebird_Sadie;5628286]Well then, forgive me for trying something new. I'll just go and delete my account and drive my car off a high ledge somewhere and rid the world of the disgrace that is apparently me.[/quote]
If you do a search here you can find other threads using everything from Rustoleum to Krylon.
I'm curious. Do you always threaten suicide when someone tries to give you constructive criticism and advice?
People here will tell you that yes, you can paint your car that way, but you can probably do a better job, that will look better and last longer,and done the right way for about the same time and money if you really wanted to.
That said, I have seen some brush/roller paint jobs that looked really good. I just don't think they look as good or hold up as well as sprayed on automotive paint.
Good luck with your paint job.
Car: 91 Z28
Axle/Gears: Stock
Well that's a bit dramatic....and so early in the morning. Your lack of homework, research, and respect for your vehicle led me to my d-bag reply. Please do not get aggravated when you defile a thirdgen then create a thread needing assistance when your half-arsed attempt fails. Please strip your car to metal and start fresh.
So, I decided to give this roll method a shot. I've sprayed with a 2-stage compressor, an electric spray gun, rattle cans, you name it. This was just a new way to apply some paint...albeit a very unique way.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 91 Z28
Axle/Gears: Stock
Yet you still decided to paint your car using a roller. An "income that knows no bounds", homework, and research most assuredly would've steered you in a different direction...the correct direction for properly painting a vehicle. Please choose your Mazda 6 as your canvas for inspiration next time.
Besides, not all of us can afford to own a thirdgen AND a nice, economical daily driver.
Yeah, a lot of these cars have had rough lives, so I hope yours has a more pleasant life as it continues to age.
As far as the fender dent, not really important how it got there but, rather, will you remove the fender and repair it properly before paint? From your original post it sounds as if you've already started the painting process without proper surface prep, and I can tell you that no amount of paint (rolled, brushed or sprayed on) will cover that.
Again, good luck!
Again, good luck!
Well, this ought to do for now. Didn't turn out too bad for what the total cost was worth.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Regardless, for only $160 it didn't turn out too bad.
Car: 91 Z28
Axle/Gears: Stock
I must say you didn't disappoint me by following up this debacle using the same boring rhetoric that's used every other time, by ever other guy that does it wrong. The "it's only temporary" and "I'll just strip it and do it right when I have the money" reasoning. Tiresome. I'll leave you alone, but end by saying you created a thread on an enthusiast website about applying paint to your car with a roller. I really hope that if you say the previous sentence to yourself a few times, you just may understand.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You could have picked up a $12 gun and $40 worth of single stage paint and learned more in the process.
There is some legitimate applications for a roller, such as high build primer. I don't do it like that, but I know it's acceptable in some applications.
I'm not an expensive paint ****. I have no issue with cheap paint, as long as it's automotive paint. Even the cheap enamel they sell at tractor supply is automotive grade. (and arguably better than the crap they used in the 80s).
edit: it just dawned on me that I saw "rustoleum automotive enamel" the other day for $22 a quart. It's a single stage but not catalyzed (like 2 stage). Is that what you used?
-- Joe
I'm not slandering you. I'm questioning why you chose a process that is known to be difficult and yield less than stellar results. Actually, I'm less concerned with the roller than the fact that you didn't use automotive paint.
-- Joe
-- Joe
Do understand, though, that I wasn't after you for slandering me: That was directed at haps. It's okay though, we can't please everyone after all. Just makes me curious as to why someone gets so worked up about someone doing something to their own car that doesn't pertain to them. Honestly, I think it turned out alright, and by the comments of others over here in my area they seem to think it's pretty decent too.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
That would be the paint I used, yes. There's no way I'd put wall paint on a car :X
Do understand, though, that I wasn't after you for slandering me: That was directed at haps. It's okay though, we can't please everyone after all. Just makes me curious as to why someone gets so worked up about someone doing something to their own car that doesn't pertain to them. Honestly, I think it turned out alright, and by the comments of others over here they seem to think it's pretty decent too.
I noticed the 'automotive enamel' the other day for $22 a quart and I was like 30 second away from picking up a quart of 'jet black' to play with.
I honestly still don't understand why you didn't use a gun. The amount of time you spend sanding and leveling after using a roller is just absurd.
But I guess worse case scenario, i'd just 320 the whole car to scuff it and hit it again.
-- Joe
Hrmm. You know, my bad. Everyone else used house paint (even recent posts). So I just assumed based on the brand.
-- Joe
-- Joe
Engine: 305 TBI
I think your car looks OK (If you like battleship grey) but I have to qualify that by saying it looks OK for the way you did it. It could have looked a lot worse but you can't expect to get respect on this forum for the method you used when even you know it's wrong. I'm also sure that there are some other young financially challenged 3rd Gen owners on here that will emulate you and do the same thing with the same results.
The bottom line is... If you're happy about the way it turned out, that's all that matters. It's your car. It's just that you could have put the same amount of money and time into doing it the right way and possibly learned even more.
Good luck with it.
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Probably a lot better than beforehand, but I really.. don't like that color. On any car.
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
It was a test run to see how rolling it on would work. Nothing like learning a new skill, and besides, if I can do a decent enough job like this, maybe it'll become a new fad for some others. Make a little bit of extra cash on the side painting civics with rustoleum, ya know? Cheap (but not necessarily quick), but it looks alright. Shines right after application too.
On to the results.
I'm sorry, but regardless of how smooth that paint came out, it looks like grey primer with a stripe on it. For anyone else doing this, red is the easiest color to look decent on a low budget job.
For yours, the only thing I can say good about it is that it would make a good base for giving it a fighter plane or Star Wars theme paint.
Car: 91 Camaro Rs
Engine: 3.1 v6
Car: 91 Camaro Rs
Engine: 3.1 v6
And one more thing I think it looks fine from the pics. Just to say for my self I used Implement enamel on mine its super thick. Its kubota orange in color. Get down on it its orange peeled. I spray it all the time when rebuilding a trade in tractor. Orange peel is its nature you should say. To each there own.
Hotrodboba400
Dec 10, 2019 07:07 PM
1Aauto
Sponsored Vendors
Sep 13, 2017 12:58 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
