tail light removel ?????????????????
Old Oct 12, 2001 | 05:28 PM
fast.as.fuc's Avatar
how do i remove the tail light centerpiece on a trans am. If i have to open the trunk is there a way to do it with out opening the trunk.
Old Oct 12, 2001 | 06:37 PM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
You need to have the trunk/hatch open to remove the taillights (unless you can fit in the trunk?)
Remove the plastic interior trim panel (large rear panel) by removing the plastic screws.
To remove the center section I think you have to loosen/remove the tail lamp assemblies themselves. All 3 pieces are connected when the lights are in place (they overlap each other). Its very easy to remove the lights, just unscrew the large plastic wing nuts.
I have done it several times, it is pretty simple. Good luck
1983 TransAm
1984 TransAm
1994 TransAm GT
1994 25th TransAm GT
1990 T-Bird SC
1971 Boss 351
Four TransAm's are not enough. Firebirds for all.
Old Oct 13, 2001 | 12:21 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
You have to have the hatch UP, there is NO other way to get it out. Unless you cut the trim piece. There are 2 screws on the top of the rear hatch trim piece that hold it down around the latch. You need a #2 Phillips screwdriver to remove them. Then you will have to remove the plastic screws and then remove the trim piece. you will have to unplug the wires for the hatch area light.
John
G O D BLESS AMERICA
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro
83 T/A
http://www.3rdgenformula.com
Old Oct 14, 2001 | 12:07 AM
alright thanks for the help but lets say there is no way to get in the trunk could i possibly use a hammer and a screwdriver (this will settle an arguement) so basically what im asking is can you remove the center piece with out damgeing it even if it means smashing the hell out of the two other lights.Thanks.
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
