t-top leak
Old Aug 30, 2013 | 07:49 PM
bucs_gators_fan's Avatar
Car: 1982 Camaro converted into an 87
Engine: 5.7 TPI
Transmission: Manual
t-top leak
I have a leak in my t-top. the water comes in at the front corner of the pass side. what is a quick fix for it?
Old Aug 30, 2013 | 08:25 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: t-top leak
If youre sure its not the heater core, look through the area you suspect.
Is there a gap between the stripping & body?
Are the drain holes plugged with dirt // debris?
When you take the top off, does it somewhat stick or release without tell-tail sounds of sticking?
How old // new is the stripping?
If its loose from the body, attach with stripping adhesive.
If all checks good, look at the alignment of the top to the roof line.
If thats out of adjustment you can adjust the top.
Remove the A pillar & rear latch cover. Under there you will see adjustment bolts.
Old Aug 30, 2013 | 08:38 PM
Engine: 5.7 TPI
Re: t-top leak
ok cool, thanks. where is the drain holes located? I never looked that close. it sticks a little bit when I pull them off. I seen a little bit of rust in the middle of the T on the body. I will look close at the alignment in the morning. thanks for the info, I appreciate it
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
1Aauto
Sponsored Vendors
Sep 22, 2015 03:39 PM
blackandblue02
Sep 10, 2015 08:19 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
