91-92 ground efx mounting plate
Old Oct 12, 2001 | 01:11 AM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Recently I purchased a set of 91-92 ground efx to install on my '87 IROCZ. Unfortunately, the mounting plate to hold the rear of the long rocker panel piece is missing. It is a metal plate that fits inside molded fittings on the top of the plastic piece, it has one stud which goes into the body.
If someone has these pieces I'd like to buy them. Since that's unlikely, I can fabricate them if a kind-hearted person provides a couple digital images and/or a sketch with dimensions.
How about it, can someone help?
Thanks in advance,
Duck
Duck_Hawaii
87 IROC-Z5.7
92 Z28-5.7 Anniversary
Old Oct 14, 2001 | 01:13 AM
Duck's Avatar
Engine: 5.7
C'mon, guys ... must be someone around that's seen one and can relate how it fits into the side piece.....
Duck_Hawaii
87 IROC-Z5.7
Old Oct 14, 2001 | 02:10 AM
Bawls's Avatar
Car: 1985 IROC-Z
Engine: LB9
Try asking the guy at thirdgenparts.com thats where I get all my cannot find in junkyard parts
No License, No Hope.
Old Oct 14, 2001 | 04:37 AM
elizabeth's Avatar
Hi, go into news and updates at the beginnng then drop down to Mike Metzer and go to his website. He has pictures (drawings) of alot of components.
Old Oct 14, 2001 | 04:53 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Since you say you can fab your own,, here's what I did (exact materials not needed)
I sheared some 18gauge stainless steel then drilled & tapped it for some 1/4-20 screws. After running the screws tight I cut the heads off the screws flush then welded them with stainless wire. Ground the welds 'flush' then used tin snips to cut to length.
Fairly simple,, very cheap (free for me) and you can make the tabs any size you want. For what you're wanting to do, I'd say 2 4-5" strips w/the stud centered would do. Mild steel is just as good,, but,, is prone to rust,, that's why I went with stainless,, plus,, stainless steel is a bit more rigid so it will hold tigher than plain mild steel. If you were to go mild steel,, I'd suggest 16-14 gauge just so the pressure will be more even against the length of the fx you're wanting to hold down,, otherwise,, you might have a gap even after tightening it. However you feel like doing it though is up to you.
*edit*
you will also want the bolt.screw no more than ¼" from the top of the piece youre making (note position in pic),, I tried to stay at about 1/8"-3/16" from the top on the ones I made so they wil slip under the fx lip easily with some room for movement.
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
[This message has been edited by deadbird (edited October 14, 2001).]
Old Oct 14, 2001 | 05:30 AM
elizabeth's Avatar
look in forum a few questions down the page and go to Jim85iroc. He has your answer in replies
Old Oct 15, 2001 | 03:40 AM
Duck's Avatar
Engine: 5.7
Thanks all, you've been a great help and I can now get on with the installation!
Duck_Hawaii
87 IROC-Z5.7
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
Mutillator
Oct 1, 2015 06:05 PM
silverstang84
Exterior Parts Wanted
Sep 21, 2015 08:05 AM
