Did any IROC's come with spacers in the rear?
Old Oct 17, 2001 | 09:44 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
Did any '87 IROC's with factory rear discs, ever come with rear spacers on the back for the wheels? Cuz the bolts for the lug nuts stick out waaay far out of the rim and the wheel looks to be slightly more recessed into the car then the front wheels.
Old Oct 18, 2001 | 12:32 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
The only F-bodies that came wth a spacer (1/4" aluminum on) were those equipped with a drum bake rear and 16" rims. Check the length of the studs compared to the front. Someone may have swapped on longer ones (as I have) for safety reasons. Some of the 1/4 mil strips like to see the wheel stud protrude from the nut. I'm using the ones that have the black plastic covers, which still fit fine.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Oct 18, 2001 | 06:59 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
My 85 IROC with disk brakes came with 1/8" spacers. My lug nuts seat tight onto the wheel with or without the spacers though. Maybe somebody put extra long studs on your car.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 18, 2001 | 08:55 AM
Z28DJP1987's Avatar
On IROC's equiped with iron drum rear brakes
a .170 thick spacers was used with the 16"
aluminum wheels. Reason was to compensate to
the same thickness as the previously used
aluminum drum brakes. These spacers should be
used to maintain the proper back spacing with
aluminum wheells & iron drum brakes.
Old Oct 18, 2001 | 09:18 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The rear end on my 85 IROC has rear discs and the spacers.
JamesC
customblackbird
Aug 15, 2021 10:16 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
kah992
Aug 19, 2015 02:55 PM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
