Trans Am front fogs, bulb replacement?
Old Oct 19, 2001 | 01:53 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Some bastard broke the drivers side glass on my foglight inside my GTA's ground FX.
Can i replace just the glass or what?
Also, how do i get to those bulbs inside anyways if i wanted to replace them with brighter ones, they have that metal protector thing in front. bulb replacement size?
Thanks!
88 Firebird, 2.8, auto
Rebuilt engine/tranny (about 20,000 on them)
*K&N air filter
*Flowmaster complete cat-back exhaust system
88 GTA Trans AM, 5.7, auto
*K&N air filter
*New MAF
(Future Mods.)
-JET chip stage II
-180 thermo.
-Flowmaster exhaust
-SLP cold air induction
-SLP intake runners
Old Oct 19, 2001 | 04:03 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
You can order a whole new lens from GM, but it's like $60. It comes with the glass glued to the metal reflector piece. The bulbs can be changed, you'd have to look at the book at the parts store to get the right ones. If you want to fix it the cheap way, you can to to Wal-Mart or your local parts store and they make after market fog lights that look identical to the ones on our cars, but the lights in these can't be changed. All you have to do is unscrew the two black tabs on the front side that hold the lens on, take the lens out, cut the wire to the light, and wire up your aftermarket light. Just be carefuly when tightening the tabs back down so as not to crack the plastic lens on the lights. There you have it -- brand new, cheap, and nobody will ever know.
[This message has been edited by Eric's85TA (edited October 19, 2001).]
Old Oct 19, 2001 | 04:06 PM
GndPrx's Avatar
I picked up a new housing with lense from TACreations and a new bulb from Autozone.
The bulb is held in by a clip on the back side of the fog light housing. Just remove the clip and the bulb will pull out. Replacement bulb was like $1.99 and the whole light assembly was only like $20 or so if I remember right in usable condition.
Carl
CarAudio Resources
CarAudio Resources Forums are now ONLINE!
Old Oct 20, 2001 | 03:01 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
I second the Wal-Mart idea. They have aftermarket lights that use the exact same size as those fog lights. I think it says "Blazer" on the box. I used them when the left side shattered, I reused the holder in the back though. They're friggin bright!
Stock 2.8 MPFI auto w/ Flowmaster 80 Series, More to come......
Pioneer DEH-11
Targa E-910 7-Band Equalizer w/ crossover
2x 10" Pioneer subs powered by 300 Watt Jensen amp
2- 6x9" Pioneer (rear)
More to come..... (hey, i dont got a job yet)
Old Oct 20, 2001 | 05:18 PM
Car: '89 GTA
Where's the website for "TACreations" ?
Thanks for the help y'all.
1992 Trans Am
May 10, 2023 07:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
TheExaminer
Aug 26, 2015 04:59 PM
mizz0313
Aug 12, 2015 06:45 AM
mustangman65_79
Aug 12, 2015 06:39 AM
