question for autobody guys?
Old Oct 26, 2001 | 12:16 PM
1982chevycamaroz28's Avatar
i have 2 questions.
1- can any autobody shop replace the floor pans? also how much estimated wound this cost to be done if like everything was taken out of the car like the carpet in the front for them to fix it? and how much estimated would it cost to buy the floor pans and then get them to put them in?
2- can an autobody shop put in the tubbed wheel wells? so i could put bigger tires in. and how much would that cost ruffly? but if a autobody shop couldnt do this how hard is it to put the tubbs in?
anyone help thanx
mods to car
new ignition system, edelbrock intake,600 cfm q-jet,th-350 tranny, used black interior, grant stering wheel, accel plugs and wires, hookercat back, b&m shifter, emmission delete package, computer delet package and soon ac delete and in future-- hooker sump comp headers, posi rear, drag slicks and all new rims probably weld rims, line lock, 8 point roll cage, strut tower brace, drag shocks, sfc, new edelbroc 600 carb, nitrous and a weiand supercharger or a 350 or 400 block
Old Oct 26, 2001 | 01:13 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Sorry, not to be harsh about this:
I have no idea why everyone wants to ask questions like how much would it be for a bodyshop to do such and such.
lemme tell you straight, go to a bodyshop and ask. Its the only way. if you get told $1000 on this board, and you go only to find out that it is actually $5000, you will be really pissed.
Sometimes there is no shortcut.
John
Old Oct 26, 2001 | 03:30 PM
twiztidz28's Avatar
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
My dad does autobody and he installs floor pans and wheel well tubs. It is pretty costly cause you have to strip the whole interior and cut and weld. I don't know the price and that would be different all over whereever you go.
86Z28, 350 gm motor, Borg Warner 5 speed, hurst shifter, 3.73's, Edelbrock heads and carb, Edelbrock headers and cat back 3" all the way, 2 1/2" cowl induction hood, and K&N air filter.
Old Oct 27, 2001 | 01:25 PM
so like how much would ur dad estimate the cost to be just ruffly?
Old Oct 28, 2001 | 08:06 PM
91SS6speed's Avatar
okay here it is just for the aftermaket floor pan you will pay 209 for each side tubs will not be nessacary . you can run in the 10,s without them If you have a rust problem might be better to find a wrecked car and switch parts obever or have someone make patch pannles if it is not to bad
91 Camaro RS SS hood wheels compucam edelbrocke intake and struttower brace sphon lca's &lcareloction brakets , adj.panhard ,eibach proline springs mac headers and subframe con. flowmasters underdrive pulleys carbua targa rs seats 94 6 speed and rearend 3.42 hurts shifter . star spech stage 3 carbon fiber clutch. mods soon to come moser 12 bolt & kenny brown street cage . then some poneys under the hood.
Old Oct 28, 2001 | 08:38 PM
hey i want to get my floor pans done becuz the front of the drivers side proabably has biger than 5x5 hole in there and its just gettin worse and i have a decent size hole behind the drive seat and i decent hole on the passenger side behind the seat and i want to get them dun so when it rains or snows it doesnt get in and also the exuast fumes dont come in from there. also i want to tub out the wheel wells becuz i want to fit maybe bigger than 10.5 in slicks under there and since my car is 20 years old and if i take the hammer to it i think ill really screw up the wheel wells. thats y.
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
Street Lethal
Aug 14, 2015 08:25 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
