C6 corvette door 'handles'? on an f-body
Old Sep 30, 2013 | 12:22 PM
minigunz's Avatar
Car: 1992 firebird
Engine: 3.1.... soon to be... bigger.
Transmission: 700r4, looking for t5
Axle/Gears: I havent a clue.
just wondering if anyone else has thought of this,
shaving factory handles off, building recess behind door into body to reach behind and hit pressure switch to pop the door open.
little bit of fab work would have to go into it, but I think end result would be very..... awesome.
Old Sep 30, 2013 | 12:24 PM
minigunz's Avatar
Car: 1992 firebird
Re: C6 corvette door 'handles'? on an f-body
was trying to upload pic for visualization, but I fail at stuff like that..... :/
Old Sep 30, 2013 | 12:43 PM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Someone did it a few years ago with a very elaborate build. A search in this thread should find it.
https://www.thirdgen.org/forums/body...one-phase.html
Pictures are on page 12
Old Sep 30, 2013 | 12:58 PM
minigunz's Avatar
Car: 1992 firebird
my question is, why isn't this a popular mod? it looks awesome!
Old Sep 30, 2013 | 02:06 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
They pop open with a button on the inside of the recessed hole in the door, but you have to have the keyfob in proximity which is actually pretty cool. No need to unlock or anything manually.. Just walk away from the car and you're good lol
Old Sep 30, 2013 | 02:32 PM
RyanJB's Avatar
Doing that would require paying a body shop to shape the door that way and then basically repaint half your car so they can blend the paint to the rest of the car unless you're okay with having a car that's in primer so you could have fancy door handles. The cost would add up quickly.
Old Sep 30, 2013 | 02:44 PM
minigunz's Avatar
Car: 1992 firebird
im looking into this mod myself, I need my car painted anyways, my hood looks like a sunburn the size of texas.... the only thing im having trouble with is figuring out how to mount the actuator that releases the door latch. I wanst planning on the key fob thing, actually for the mechanism, I was planning on using the mech. off of the trunk for like a 98 Bonneville and using the facory lock mech. as long as its locked as many times as you hit the button, the door wont open. the only corvette part I would use would be the actual pressure switch itself. maybe not even so, corvette parts are crazy expensive.
Old Sep 30, 2013 | 02:48 PM
minigunz's Avatar
Car: 1992 firebird
yea! using the keyfob would be cool. I think the system relies heavily on the computer to operate though, none the less if it could be figured out, push button ignition, remote start, walk away locking.....ah man..
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Dec 10, 2015 08:16 PM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
scottmoyer
Sep 7, 2015 07:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
