Speedo problems
Old Oct 27, 2001 | 06:39 PM
92RSGUY's Avatar
Speedo problems
I just replaced my 110mph speedo with a 145mph speedo. Every gauge works fine, except for the speedo. It just bounces back and forth between 35mph and 0. Any ideas?
Old Oct 27, 2001 | 10:17 PM
Camarokid01's Avatar
did you take apart the speedo at all? is the speedo cable hooked up and tite? I dunno if any of those would cause that but just to make sure.
Old Oct 28, 2001 | 01:20 PM
hot89camaro's Avatar
make sure the speedo cable is operating freely. If it binds in the housing, it is possible for it to basically wind itself like a spring, and then snap loose, causing the 30 mph (or so) reading!! Good luck
Old Oct 28, 2001 | 06:25 PM
92RSGUY's Avatar
It's in a 92RS, so there is no cable, it's electric. I pulled it back out and replaced it making sure everything was making contact, but it's still doing the same thing.
Old Oct 29, 2001 | 12:12 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
What year is the cluster out of. Might need to change the VSS Buffer module. I am not 100% sure.
Do you know if that cluster was working before you got it?
WS6 Trans Am.
View My Ride @ thirdgen.org
Old Oct 29, 2001 | 07:34 PM
92RSGUY's Avatar
I'm not sure if the cluster worked before or not. It's out of a '92 Z28. When I pulled it out I noticed the ribbon cable on the back is a little bent up on the speedo, but it wasn't torn.
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
