Power window motor, Help, which one?
Old Oct 5, 2013 | 02:06 PM
transambill's Avatar
Car: 91 Firebird Formula
Engine: ZZ4 fast burn with TPIS mini ram.
Transmission: Viper T10 6 spd.
Ok, the power window motors on my 91 Bird are getting week and slow to raise and lower the windows.
What are and where can I get the best replacements so I don't have to do this again a few years down the road?
Thanks for the help, Bill.
Old Oct 5, 2013 | 09:18 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: Power window motor, Help, which one?
Look around for posts. Ideally, you'll want to clean the regulator tracks and then lithium grease them. If you need a motor, they're readily available at any shop, Rock Auto.com or I got mine from 1AAuto (they have employees who are members here).
Old Oct 6, 2013 | 06:38 AM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
part of the problems with the windows is the voltage drop from the battery to the window switches.im going to run a fused 10 guage wire from the battery directly to feed the window switches and see if that helps.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
stalkier
Aug 13, 2015 12:59 PM
