can't seem to get the passenger door panel off
Old Oct 30, 2001 | 04:37 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
I found a rattle from the loose connection of the black window thingy (really tech) and the red panel. I have a hot date friday and don't want it rattling. I went to take the panel off and I can't get the black peice to unlatch. I've pulled the drivers side before to replace the window motor, so I'm not sure what I'm doing wrong, the panel is just hanging threre. Please help a guy out asap. It doesn't look good when a first date involves her saying "I love the red leather againist my body and the bare metal on my right arm"
late model 91 rs, fully loaded, auto, t-tops, red leather, paint- gm red and yellow blend (light red), custom painted 16" Camaro rims
305 tbi flat base 14"x3" with K&N, hypertech chip, accel super stock plug wires, only use full synthetic oil and delco filter, 2 1/2" cat delete pipe, Edelbrock 3" cat-back
MTX sub and amp, Bose all around
vic_v8@yahoo.com
street kills: New v-6 stang, 96 v6 camaro, totally killed '86 SC Camaro (305), 91 z 28 with 305
15.854@87.57 (I think I could have it 15.5 with good tires and two more runs)
next month: rest of ultimate tbi
Old Oct 30, 2001 | 08:14 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
you have to "bop" the plastic trim piece on the top of the door panel wth your palm toward the outside of the car, while pulling gently up on the trim piece. If I remember right there ar 3 or 4 latches that snap onto the door frame. installing is easier.
(I should write a tech artical).
John
Old Oct 31, 2001 | 07:11 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Make sure the window is down, and "bop" it like mentioned above, or squeeze it into the door as you lift up. It's a pain in the *** the first time, but once you figure it out you'll be set.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 31, 2001 | 12:00 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
<font face="Verdana, Arial" size="2">Originally posted by okfoz:
John
</font>
Done, sort of.
http://www.geocities.com/camman86/ex...paintprep.html
About half way down, paragraph starts with something about removing mirrors and door handles.
[This message has been edited by Mikes86SC (edited October 31, 2001).]
Old Oct 31, 2001 | 07:09 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
thanks guys, i got it, drivers side was a lot easier
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
kkirch15
Interior Parts Wanted
Aug 28, 2015 10:03 AM
Out-Cast
Aug 23, 2015 06:33 AM
evan555222
Aug 22, 2015 07:14 PM
