removing rear bumper cover
Old Oct 31, 2001 | 03:58 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
i'm changing over to ground effects, and i was wondering how do i get the rear bumper cover off. i see the 3 bolts on each side, but i have no idea how i'm supposed to get at them
Old Oct 31, 2001 | 04:19 PM
Thirdgenfbody.com's Avatar
Remove the side panels, and you may have to remove the rear panel as well, you will see 3 bolts on each side, undo those and it slides right off
arthur@thirdgenfbody.com
www.thirdgenfbody.com
1985 IROC Resto underway
Old Oct 31, 2001 | 04:26 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Extensions and swivel sockets . After that, you have to remove the plastic locks on the bottom of the bumper, then remove the tail lights to get at the plastic locks on the top of the bumper. I'm sure GM has a special tool for removing the locks that probably sells for $100+, but I just use a pliers. You first have to pull the center out about 1/2 inch, then the entire piece pulls out.
Miles
88 427 Big Block Camaro
(Best 1/4) 12.18 @ 113mph 1.75 60ft
(Best 1/8) 7.76 @ 94mph 1.72 60ft
Currently installing 3.73's into my 9 bolt (YES, it is a 9 bolt & YES they are 3.73's, not 3.70. I currently have 4.10 gear sets and new series 3 posi carriers for sale for 9 bolts )
www.koolmeister.com
Old Oct 31, 2001 | 06:41 PM
Diabolical's Avatar
Engine: 305HO L69
ok, before i bother attempting it, at the risk of having to come back on here to make another post, and have to wait for an answer, how do i remove the taillights?
Old Oct 31, 2001 | 09:21 PM
Abubaca's Avatar
SOOOOO EASY! I pulled one off in the junkyard, having never done it before, in about 5 minutes.
1. remove rear plastic interior piece(loosening the side pieces wouldn't hurt either).
2. remove the 4 BIG black wingnuts on each tailight.
3.gently pull out the tailight so you can see the wiring harness for each bulb...then just twist and pull. The license plate bulb was tricky the first time, you just have to figure out how to get your fingers in there.
Also- while they're out, blue coral plastic polish/cleaner makes 'em like new...almost!!!
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
