Stripped torx bolt
Old Oct 12, 2013 | 08:46 PM
mav75's Avatar
Car: '89 Trans Am
Transmission: 700 R4
Stripped torx bolt
I went to replace my rear hatch struts tonight. The first strut went fine, but then I completely stripped the torx bolt at the base of the second one. I tried hammering the torx bit in to give myself a little bit of grip, but it didn't work. Any suggestions?
Old Oct 12, 2013 | 08:56 PM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Re: Stripped torx bolt
Vise grips
Old Oct 12, 2013 | 10:04 PM
mav75's Avatar
Car: '89 Trans Am
I like that idea. It saves money on an easy out.
Old Oct 13, 2013 | 11:16 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
If the vise grips don't work you could weld a nut onto it. Clean the paint of the bolt and weld the inside of the nut to the bolt head.
Old Oct 13, 2013 | 08:24 PM
Mad Myche's Avatar
Car: 89 Camaro RS
Engine: 2.8 V6
Transmission: Automatic
Other options would be trying to hammer an allen wrench into or using a grinder to cut a slot in for a flat blade screwdriver
Old Oct 13, 2013 | 09:30 PM
mav75's Avatar
Car: '89 Trans Am
The vise grip worked! I was even able to find a replacement bolt online. Hopefully when it comes, it'll be the right one. With a little bit of luck, it should all be taken care of before Friday.
Old Oct 18, 2013 | 07:33 PM
Gus_Mahn's Avatar
Glad you got it. Next time coat the torx bit with lapping compound. It will grip much better without stripping.
Old Oct 18, 2013 | 09:09 PM
mav75's Avatar
Car: '89 Trans Am
It turns out that I was using a T40 bit instead of a T45. Just enough to barely bite, but not enough to do the job correctly.
Oh well, lesson learned. Luckily it was only an $8 bolt.
Old Oct 18, 2013 | 09:59 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Should be a T47... Same as the seat belt buckle bolts...
Old Oct 19, 2013 | 02:49 PM
mav75's Avatar
Car: '89 Trans Am
Guess I got lucky. The T45 seemed to fit really well.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
fasteddi
Sep 10, 2015 09:32 AM
Jlanz55
Sep 6, 2015 07:28 PM
Amillionoh7
Sep 5, 2015 11:44 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
