Door install???
Old Nov 2, 2001 | 12:08 AM
formula88bird's Avatar
Door install???
Is there an easy way to take off the upper hinge mounts bolts without removing the fender?? If so what tools would I need?
Old Nov 2, 2001 | 08:01 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I have been told that on the driver side it is possible to remove the inner fender plastic cover and reach through. never tried it, but it sounds promising.
The passenger side might be a little more tricky sice there is the antenna in there.
John
G O D BLESS AMERICA
http://www.3rdgenformula.com
87 Formula 5.1 TPI Auto Modified (Yellow/Black)
87 Formula TPI (5 Speed) Yellow/Gray STOCK
14.8sec 1967 Buick Riviera
1990 Buick Riviera
83 Camaro
83 T/A
Old Nov 2, 2001 | 11:33 PM
Thanks I'll try that, if it works I will post back.
Old Nov 3, 2001 | 04:43 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Just curious,why are you removing the door?
Old Nov 3, 2001 | 05:51 PM
JJ IROC's Avatar
I don't know what the differance between Camaro and Firebirds are when taking off the doors but you can get a box end wrench in there to get the upper bolts out. If you have a ratching box wrench that will work too.
JJ IROC
1987 Camaro IROC Z-28 383ci. TPI 6 Speed T-56 black
My Car
jjiroc@alijas.com
Old Nov 4, 2001 | 01:08 AM
I am removing the door to replace it. Some drunk in a 4x4 creased it and messed up the inner support bar and it also sags real bad.
Thanks for responding guys.
Old Nov 4, 2001 | 10:06 AM
bradkeith's Avatar
I removed both my doors with a box-end wrench. It is timely, but it works.
1986 camaro with 92z28 gound effects, aero wing, 4 3/4 Unlimited products cowl, 3.90 auburn gear rear-end with Steve Spohn adj LCA's,Panhard bar. 406 stroked to to 429 motor in the works to replace 2.8. just my 2 cents
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
