back seat help, searching didn't find it answer...
Old Nov 7, 2001 | 07:03 PM
86bird_28v6_5spd_ramair
Guest
Posts: n/a
what i was to do is take out the back seak but the back part that folds down, there seam to be maybe a hex screw in it but there is no room to even try a socket.
anyone done this and found an easy way to get it out, plz give me detail.
http://PCperformance-usa.com/86bird/86bird.html
Old Nov 7, 2001 | 07:51 PM
scott's85T/A's Avatar
there is a hinge on the corner of the seat that has a threaded stud going down with a nut on it(can't remember what size) I used a small ¼ in. rachet to get mine off(with the socket facing up)It is a tight fit but once you find the nut and get it started lift up on the seat to gain a little more room as you go.
Old Nov 8, 2001 | 12:48 AM
Camarokid01's Avatar
I got mine with a wrench.
Old Nov 8, 2001 | 06:46 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
13mm if I remember correctly.
Old Nov 8, 2001 | 11:47 AM
LFN AT U's Avatar
Car: 2004 Chevy Avalanche
Engine: Some that run, some that don't
Transmission: 700R4's, a T-5, and a Turbo 350
It's pretty easy to get at that once the bottom part of the seat is out. The bottom sections are held in place by one 13mm bolt at the front of the seat.
Old Nov 8, 2001 | 11:55 AM
GndPrx's Avatar
total 2 bolts and 2 nuts, all 13mm
remove the bolt from beneath the center of each bottom seat portion and remove the bottom seat cushions. Remove the nuts from each corner hinge and lift out the back portion.
Install reverse of removal
[--typo edit--]
Carl
CarAudio Resources
CarAudio Resources Forums are now ONLINE!
[This message has been edited by GndPrx (edited November 08, 2001).]
Old Nov 8, 2001 | 04:30 PM
Guest
Posts: n/a
well that makes sense, remove the bottoms first, duh
but it is tight in there
lee01
Apr 9, 2016 01:56 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
justin57
Aug 20, 2015 07:05 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
