Repair or replace the doors???
Old Nov 11, 2001 | 11:25 AM
Chris Sartori's Avatar
Hi All,
Just wanting some input and comments on a idea I had. My doors have a bubbled rusty area about the size of a softball. Not all the way thru though. And a couple of small dings. Would it be easier to replace the doors or repair them? I dont like the idea of bondo or fillers that might crack or come out later. Does anyone know how much do they cost?
Thanks,
Chris
Old Nov 11, 2001 | 06:27 PM
Belker's Avatar
If there's not a hole ... I'd repair. Just make the effort to do it right the first time.
Old Nov 12, 2001 | 09:48 PM
killrog22's Avatar
repair, repair, repair. I am changing the door on my 91' RS. Pain in the you know what. If you do decide to replace the door, the only way to get to the back bolt on the bottom hinge is to take off the inner fender and reach in from the wheel well.
Old Nov 13, 2001 | 03:28 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
You should repair it. That should keep costs down. Do not worry about Bondo, it is tougher than you think. unless you have a lot more than 3/8 of an inch thick it should hold up great.
For minor wrinkles you can get some filling primer that when used it builds really fast, sand it down for a smooth finish.
On my car (it was in a hail storm) we used fill & glaze, now my car is straighter than it came out of the factory.. I can show it at big car shows like St Ignace (I think 3000 cars last year) and no one will ever know unless I tell them (like I did you). "Fill & glaze" is a higher grade bondo type product. "Bondo" I believe is a brand name like Kleenex.
John
G O D BLESS AMERICA
http://www.3rdgenformula.com
87 Formula 5.1 TPI Auto Modified (Yellow/Black)
87 Formula TPI (5 Speed) Yellow/Gray STOCK
14.8sec 1967 Buick Riviera
1990 Buick Riviera (driver)
83 Camaro
83 T/A
[This message has been edited by okfoz (edited November 13, 2001).]
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
86IROC112
Apr 9, 2016 10:20 PM
BlackTopKing
Aug 19, 2015 12:13 PM
