4TH Gen Leather
Old Nov 13, 2001 | 03:53 AM
Purple Monkey's Avatar
Car: 1990 Eagle Talon TSi AWD
Engine: 4G63T
Transmission: 5 speed
4TH Gen Leather
Hey, I just scored a set of grey leather seats from a 94 T/A for really cheap. My question is, How do you hook up the power lumbar support? I can splice it all easily, Just need to know what wires do what...
Old Nov 13, 2001 | 03:20 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
you should have only 2 wires a black & a red or orange wire. The black is ground, the red is power.
I think the plug will be the same from any year camaro/firebird with power seats.
Go to salvageyard & remove a power seat. Then unscrew the door jam trim pice on the bottom that covers part of the carpet. & take out the kick panel on the driver side. Take a razorblade and cut along the front seat support to access the wire. Unscrew the ground wire going to the body. Pop open the wire loom & follow the wire up to under the Instrument Panel & unplug it.
Plug it into yours & run the wires.
Actually what I did was take 2 sets of wires and plug them both in. I might be the only or one of the very few to have BOTH a 6 way power seat & the lumbar support. I now have a 14 way power seat.
This method might be a little more time consuming, but it is done right & worth it. In the long haul it is easier to work on.
John
G O D BLESS AMERICA
http://www.3rdgenformula.com
87 Formula 5.1 TPI Auto Modified (Yellow/Black)
87 Formula TPI (5 Speed) Yellow/Gray STOCK
14.8sec 1967 Buick Riviera
1990 Buick Riviera (driver)
83 Camaro
83 T/A
[This message has been edited by okfoz (edited November 13, 2001).]
Old Nov 13, 2001 | 11:41 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I hope you got the power and air tube that runs from the drivers seat to the passenger seat.
It's 2 wires for main power to the drivers seat and 2 or 3 wires that go from the drivers seat to the passenger seat, can't remember. The pump is in the drivers seat so they have to be wired together.
WS6 Trans Am.
View My Ride @ thirdgen.org
Frozer!!!
Jan 19, 2024 04:55 PM
cam-mike
Aug 24, 2015 07:23 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
