Weld at home or shop floor pans?
Old Nov 10, 2013 | 11:08 AM
jjcuff1's Avatar
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
Weld I have some small spots in floors about 6" thinking of cutting out and weld in some metal
But looking at lowes it will be several hundred to just get a welder tools cutter etc
For this small job and gonna have good body shop pair anyway it seems even for $100 a floor pan welded in by a pro it is cheaper the. Home
I am in apt and not doing a lot of welding that I need it. Rather spend on engine parts
Old Nov 10, 2013 | 11:17 AM
Joe Tag's Avatar
Re: Weld at home or shop floor pans?
A few things to weigh out here. Foremost, your skill level, are you confident you can do this? How much will the shop charge to do this? If you can do it yourself and have the tools afterwards for about the same cost go for it. Will you need a welder in the future? Owning and restoring a 20 - 30 year old car, probably so. Can't make the decision for you, only you know what you can do.
Old Nov 10, 2013 | 05:07 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
you arent going to get a welder that is worth a crap for a few hundred let alone 100. and it will take some practice before you can weld sheet metal. but if you want to learn and want to be able to do things in the future the pans are not going to be seen so its not a bad thing to practice on.
gixxer92
Sep 1, 2015 04:32 PM
TheExaminer
Aug 26, 2015 04:59 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
Amillionoh7
Aug 7, 2015 01:24 PM
